Activity Forums Adobe Premiere Pro FLV Exporting red frames
  • FLV Exporting red frames
    Posted by Chad Mayeux on February 3, 2009 at 7:25 pm
    I have recently been exporting several 1-2 minute sequences as flash files using the Adobe Media Encoder and have recently noticed in some of the videos 1 or 2 solid red frames were added randomly in the video. When I went back into premiere to check the source, they (red frames) were there. So apparently this happened before export. The clips that have the red frames were subclips from a larger clip that was captured via a DV deck.
    I then took the red frames out in premiere and exported them to FLV again and the resulting video is perfect. Any ideas about where the red frames are coming from?
    Chad Mayeux
    Metter, GA
    Pineland Technology Solutions
    Videographer/ Digital Artist
    Chad Mayeux replied 17 years, 7 months ago 2 Members · 2 Replies
  • Jon Geddes
    February 4, 2009 at 1:23 am
    It’s most likely a codec issue from the DV footage. I’ve experienced the same red frames when importing .wmv files into AE. Sometimes AE just doesn’t work well with certain codecs. Which one are you using by the way?
    Jon Geddes
    Motion Graphics Designer
    http://www.precomposed.com
  • Chad Mayeux
    February 4, 2009 at 1:38 pm
    Ok i was a little mistaken, the footage with the red frames was not from the raw DV footage. The DV footage had been burned to DVD and I lost the original DV footage and project file so I copied the VOB files from the DVD onto my desktop and then used MPEG Streamclip to convert it to MPEG so I could bring it back into premiere and edit it. So it must have happened when I converted it to an MPEG. Very strange
    Chad Mayeux
    Metter, GA
