Activity › Forums › Apple Final Cut Pro Legacy › FLV export FCP6 Audio trouble
Posted by Kerry Villamil on June 17, 2009 at 10:11 pmHello,
I am trying to export an FLV from FCP6.Using quicktime conversion, I am able to export video as an FLV, resize, crop and make whatever other adjustments I need.
However … All I get is video. No audio channels. I do have the “embed audio” button checked in the audio tab of the”Options” dialog box. But still, there is no audio in the final exported FLV.
Help!!!
Thanks in advance,
KerryJohn Fishbackreplied 17 years, 3 months ago 3 Members · 4 Replies
John Fishback
June 18, 2009 at 3:31 pmI’m not sure what’s going on. How are you playing back the flv? Is the audio codec selected in the encoder installed on your Mac? Describe your settings.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Kerry Villamil
June 18, 2009 at 4:46 pmThanks for responding.
I’ve tried playing back the videos in Quicktime, MPEG Streamclip and Real Player.
I work on a:
Processor: 2 x 2.66 GHz Dual-Core Intel Xeon.
Memory: 2GB, 667 MHz DDR2 FB-DIMMThe only audio codec option I have is MPEG 3.
Kerry
David Roth weiss
June 18, 2009 at 4:50 pmQuicktime does not have it’s own Flash encoder. Exporting FLVs with Quicktime Conversion is an accidental workflow that only happens when Adobe Flash and it’s components are installed on a FCP system, and it is imperfect at best.
So, you have three options:
1) Get a dedicated Flash encoder
2) Get a dedicated Flash engine (other than the one in Adobe Flash) that installs in all Quicktime Components
3) Encode to an .h264 Quicktime and simply change the suffix from .mov to .flv (which works in almost all situations)
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
John Fishback
June 18, 2009 at 7:41 pmFrom your earlier description it sounds as if you might have Flash Encoder installed. It has an Embed Audio control. You may have encoded the file properly, but not have a player for it. Checkout this free swf-flv player from Eltima:
https://mac.eltima.com/freeflashplayer.htmlJohn
