Activity Forums Apple Final Cut Pro Legacy FLV Export Component
  • Antoine Vuduc
    May 10, 2010 at 9:38 pm
    As i don’t use FCP, i give you a tip from simple user:
    export in .flv is not the only way to make flv file…
    Flash Player CAN play H.264… so you just have to export in H264 format and change ( yes ! ) the extension ( .mov often kept after export by the most like Quicktime 7 Pro )…by .flv
    for exemple, in Quicktime 7 Pro, export your video in sequence with option H.264, you will obtain a .mov
    Just change mov by flv and it will be oK.
    Hope that helps.
  • Emma Kha
    June 3, 2010 at 1:08 pm
    I have the same probleme with FCP 7, I can’t make an .flv file. and the older flv component don’t work.
    How do you to make a flv file, now ?
    can you answer me ?
    Thanks !!
  • Mark Maness
    June 3, 2010 at 2:45 pm
    Wow! Its so simple, you’re going to slap yourself when you hear it.
    Export your program and compress in Compressor as a Quicktime H.264 file. When its done, you’ll have a quicktime movie with a .mov extension. Now, here’s the neat part… Just change the extension to .flv, the OS will ask you if this is OK, click on OK. That’s it. You now have an H.264 flv movie that can be used on a Flash website.
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Emma Kha
    June 4, 2010 at 8:58 am
    Ok, I see, but the size is not the same …. insn’it ?
    I’m afraid it’ll to “weightly”
    and how re-size the size in pixels, too ?
    Humm; humm, sorry, I ve got many question 😉
    thanks for your help
  • Robin Kress
    October 2, 2010 at 9:54 am
    Hi Antoine
    That is of great help thank you! i unfortunately do no have CS3, just CS5, which i bought recently.
    Could you do me a huge favour and e-mail me the FLV.component file?
    my e-mail address is: robin@lezardbleu.co.za
    I would greatly appreciate that! Thanks so much!
  • Mark Maness
    October 2, 2010 at 11:59 am
    You don’t need this file. CS5 expects your Flash file to be in the H.264 codec. If you need to compress anything other than H.264, use the Media Encoder with CS5. If you have installed CS5, you already have everything you need.
    Wayne Carey
    Schazam Productions
  • Carol Leigh
    October 18, 2011 at 9:05 pm
    OMG—I never kn ew that about the H.264.
    BUT I have a serious question. The good thing about flash was that it looked good at low bandwidth, but doesn’t h.264 require a bit more to look decent. I am concerned because we need a low bandwidth option.
Page 2 of 2
