Activity › Forums › Compression Techniques › FLV conversion optimized for Adobe Connect 9
  • FLV conversion optimized for Adobe Connect 9
    Posted by Wis House on December 6, 2012 at 8:39 pm
    A step-by-step process for converting videos into FLV files for use in Adobe Connect.
    STEP 1: Open Adobe Media Encoder
    STEP 2: Drag & Drop the video file you want to convert into Adobe Media Encoder.
    NOTE: Media Encoder does not handle .MOV files. You may need to transcode into a .mp4 format before doing this.
    STEP 3: Select FLV ❘ F4V from the dropdown menu under Format.
    STEP 4: Select the Settings… button on the right side of the interface.
    STEP 5: The settings window will appear. Click the Format tab in the bottom-right section.
    STEP 6: Inside the Format tab, confirm that the circle next to FLV is selected:
    STEP 7: Click the Video tab. Confirm that the video settings are as follows:
    STEP 8: Click the Audio tab. Confirm that the audio settings are as follows. Click OK.
    STEP 9: This will bring you back to the main window. Click on the text under Output File.
    STEP 10: This dialogue window will appear. Select where you want your flv video. Click Save.
    Step 11: Make sure you have your settings the way you want them and then hit Start Queue in the upper-left corner.
    By:
    John Lendved, Rob Fontella, & Alan Talaga
    The Wisconsin Clearinghouse for Prevention Resources
    Check out our video stories at https://www.preventionspeaks.org/stories
    Craig Seeman replied 13 years, 9 months ago 2 Members · 1 Reply
  • Craig Seeman
    December 11, 2012 at 12:37 am
    [Wis House] “NOTE: Media Encoder does not handle .MOV files. “
    Seriously?
    Adobe Connect is at version 9 I believe.
    You’re showing CS5 for AME whereas current version is CS6.
