Activity › Forums › Apple Final Cut Pro Legacy › Flutter in video of stills
  • Flutter in video of stills
    Posted by Larry Lancit on March 18, 2011 at 2:37 pm
    I am editing a piece in FCP7 using video from a flipcam. I MPEG Streamclipped it to be .mov files for stability. When I try to insert still pictures into the piece, it looks fine in the timeline, but when I export as a .mov file, the still pictures have a flutter in the video. Can anyone help me stop the flutter?
    Chris Tompkins replied 15 years, 6 months ago 2 Members · 3 Replies
  • Chris Tompkins
    March 18, 2011 at 4:19 pm
    Sequence settings?
    Format & Size of stills?
    Do you export “current settings”?
    Chris Tompkins
    Video Atlanta LLC
  • Larry Lancit
    March 19, 2011 at 10:13 pm
    Hi Chris–The sequence settings are DV NTSC 48Khz
    The format of the pix are jpg., and are too small, so I enlarge them in the canvas. When I export, I export as a self-contained quicktime movie (.mov)
  • Chris Tompkins
    March 20, 2011 at 12:11 pm
    It’s comes from:
    Low rez jpegs.
    DV compression.
    I would recommend using higher and larger quality stills.
    Change sequence to DV50 or higher.
    Try again.
    Chris Tompkins
    Video Atlanta LLC
