Activity Forums Adobe Premiere Pro Fluro lights flicker
  • Fluro lights flicker
    Posted by Bj on June 7, 2005 at 12:59 am
    i have a flicker from office fluro lights. Any ideas what effect/filter i can use to get rid of it.
    David J replied 21 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Aanarav Sareen
    June 7, 2005 at 3:12 am
    How bad are they? and also depends on the situation. You can probably trick the viewer and repeat one of the prior non-flickering frames.
    Aanarav Sareen
    Adobe Certfied Expert, Premiere Pro
    https://www.asvideoproductions.com/video
  • Craig Howard
    June 7, 2005 at 3:51 am
    I doubt you can fix it because the “flicker” is usually accompanied by a phase effect that dims and brightens the output of the fluro over a short time.ie ..its not actually an on/off flicker but more lke a sine wave.
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • David J
    June 7, 2005 at 8:54 am
    If you have a fixed camera, you could always take a still, cut out the lights, and paste the non-flickering still over the flickery bits.
    Or use a matte to isolate the lights on a copy of the video and experiment with the echo filter to blend several frames together to see if that might reduce the flicker.
  • Shane Chadder
    June 8, 2005 at 1:32 am
    I assume this is footage shot with an NTSC camera in the land of 50Hz power?
    I’ve done a frame blend effect with Discreet edit that helps even things out if there isn’t a lot of motion in the segment. I don’t know Premiere well enough to suggest how to replicate that.
  • Craig Howard
    June 8, 2005 at 3:29 am
    The flicker wont only be seen on the light sources (the tubes)…it will also be seen on what ever they are illuminating (usually)
    Craig
    Auckland
    New Zealand
  • Shane Chadder
    June 9, 2005 at 1:57 am
    Right but blending frames evens the flicker out because you mix adjacent frames. I haven’t been on an edit system for a while to recall exactly how it works. But it does help considerable. You might play with putting the footage down twice offset by a frame and play with the transparency of the top track.
  • David J
    June 9, 2005 at 10:38 pm
    Funnily enough, although no-one seems to have noticed, blending frames as a way to reduce flicker was why I suggested trying the echo filter in my earlier response.
