Activity Forums Adobe After Effects Fluorescent Tube
  • Fluorescent Tube
    Posted by Matt Robinson on January 13, 2011 at 6:59 am
    Hi all,
    I am wanting to create a fluorescent tube light effect and am a bit stumped are there any good tutorials on creating this effect? I am thing mask a white solid, add glow and add a point light? But unsure, help will be greatly appreciated.
    Regards MD
    Jason Mettler replied 15 years, 8 months ago 4 Members · 3 Replies
  • Michael Szalapski
    January 13, 2011 at 2:34 pm
    You would only need to add a light to the scene if the other layers in your scene are 3d and I would add a bunch of point lights along the length of the layer and tie their values together with expressions to a controller layer so that you can control them all at once.
    Why more than one? A fluorescent tube isn’t a point; it’s a line. It’s the best AE way I can think of to fake that.
    If you add a bit of a wiggle (amount controlled by a slider on the controller layer) on each light’s brightness you could also get that horrible flicker that fluorescents provide.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Tudor “ted” jelescu
    January 13, 2011 at 5:25 pm
    If you do not have extensive camera moves in a 3d space (that is if you even have a 3d comp) you are on the right track with the idea of a shape and glow. Using the shape or even image of a florescent tube with a glow in a 32bit comp with a intensity/radius animation to give the flicker is a good way to go.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Jason Mettler
    January 13, 2011 at 10:10 pm
