Activity Forums Apple Final Cut Pro Legacy Fluorescent lights
  • Fluorescent lights
    Posted by Anthony Faulkner on June 16, 2009 at 10:21 am
    I have some NTSC DV footage that has a nasty fluorescent flicker in a section in the background. is there any way i can remove it? And is there any way to shoot around it. I sometimes have to shoot in an office environment and cannot turn the overheads off….
    thanks for any help!!
    I accidently posted this elsewhere after a search left me in a different forum!! oops!
    Anthony
    Anthony Faulkner replied 17 years, 3 months ago 5 Members · 6 Replies
  • Arnie Schlissel
    June 16, 2009 at 11:28 am
    There’s a deflicker plugin in the Furnace set from the Foundry. I’ve never tried it myself, but I think there’s a demo.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Mike Johnson
    June 16, 2009 at 1:49 pm
    You might try using a subtle strobe effect to remove the flicker from the footage you already shot.
    To prevent the flicker while shooting, try adjusting your shutter speed until the flicker stops.
    Mike Johnson
    Final Cut Pro Editor
    Drury Outdoors
    http://www.druryoutdoors.com
    View Mike Johnson's profile on LinkedIn
  • Ed Dooley
    June 16, 2009 at 2:47 pm
    The only problem with Mike and Arnie’s solutions is that you say the flickering is only in the background, not the foreground. If you add de-flickering or strobe (which would help some, but not too much anyway),
    you’ll partially fix the strobing background, but make your unstrobing foreground start to strobe/flicker. Either you have to isolate the background and try the filters on just that, or use the Reshoot Filter, which always works.
    And, as Mike said, setting the shutter speed to the flourescent flicker rate (or double the rate) will make it go away. For instance, when I shoot in 50Hz countries, I set the shutter to around 100 for flourescent.
    Ed
  • David Bogie
    June 16, 2009 at 5:41 pm
    [Ed Dooley] “or use the Reshoot Filter, which always works. “
    Ed, can I use this? I don’t know if I’d be able to give proper credit each time.
    bogiesan
  • Ed Dooley
    June 16, 2009 at 6:13 pm
    I stole it from an old Philip Hodgett post, so….. be my guest!
    And if you do give credit, please don’t say “I got this from Ed, who stole it from Philip. 🙂
    Ed
  • Anthony Faulkner
    June 17, 2009 at 2:57 am
    Thank you guys all great information!!
