Activity Forums Maxon Cinema 4D fluid dynamics tab in X particles 4…
  • fluid dynamics tab in X particles 4…
    Posted by Danny Perez-triana on August 31, 2018 at 8:10 pm
    Hey everyone, I’ve been trying to learn x particles and been taking all the tutorials I can. I’ve run into a discrepancy, difference between x particles 4 and previous versions that old tutorials are based on.
    I’m trying to find the fluid ‘dynamics’ tab so that I can set two fluids/emitters to interact with and against each other.
    Attached are photos of the settings I’m looking for. The images are from the tutorial and the one is from the version 4 I’m using.
    I found some comparable settings in the fluid data section(attached image) but not everything.
    I don’t know if it’s just called something different in the newer version but I was hoping someone here might be able to point me in the right direction?
    hope all is well and people have some time off this weekend,
    thanks!
    Ignacio
    Brian Jones replied 7 years, 12 months ago 2 Members · 1 Reply
  • Brian Jones
    August 31, 2018 at 8:24 pm
    it’s probably best to watch some XP4 fluid tutorials instead, the changes are fairly substantial in fluids, then work backwards to the old ones
