Activity Forums Adobe After Effects flowing text along a path in 3rd dimensions?
  • flowing text along a path in 3rd dimensions?
    Posted by Sans.otto on May 8, 2007 at 4:51 pm
    hi guys I need your help with text,masks and paths!:D
    I have a long text in AE; I added it a mask and than I used this mask with a path for the text. It works well, there is the text that flowing along the path!
    Now I want to flowing the path(and text also) in thirddimensions like a fall.
    how can I do that?
    I tried to edit the point position path
    Is it possible?:D
    thanks all,
    Andrea
    Sans.otto replied 19 years ago 2 Members · 2 Replies
  • Mike Clasby
    May 8, 2007 at 5:12 pm
    If you are taling Spiral, there are two tuts that do what you are asking, but neither is simple:
    https://www.creativecow.net/articles/langley_david/3d_ribbon_text/index.html
    https://www.creativecow.net/articles/chao_joe/textstream/index.html
    If you just want the text to fall, precomp the text layer and make it 3D, then animate it’s fall, but it will be flat-one piece of text.
    AE Text, with the text tool is 2D. I think text in AE CS3 is going to be 3D (if I remember correctly), so this will probably be a preset there… I’m hoping.
  • Sans.otto
    May 8, 2007 at 6:20 pm
    eheh I have to try AE cs3 as soon as possible!:)
    Thanks so much for these great tutorial! I getting done my text-river with expressions…I hope|:)
    If someone else know other tips about text in 3d space He’s welcomed!:)
    thanks all,
    Andrea
