Activity › Forums › Adobe After Effects › Flowers going in a circle
  • Flowers going in a circle
    Posted by Hope Holmesby on March 10, 2013 at 1:12 pm
    Hi, thanks for reading…
    Would like to place 6 movies of blooming flowers. They would be forming a circle on the screen, then have them all rotate around in a circle.
    What I mean by circle is: Image the face of a clock and they are all rotating around the rim of the clock, equally spaced. All staying upright.
    How can one do this easily, wo animating each one individually w its own key frames.?
    Thanks so much for your thots..
    Warmly,
    Hope
    __________________________________________________
    Life is here to enjoy.
    iMac 3.5 GHz Intel Core i7, 2TB; Mac OS 10.6.8, 16 GB RAM; 2 La Cie external HDs 1 TB each; After Effects CS5.5; Sound Track Pro 3.0.1; Final Cut Pro 7.0.3; Compressor 3.5.3
    Hope Holmesby replied 13 years, 6 months ago 2 Members · 4 Replies
  • John Cuevas
    March 10, 2013 at 1:26 pm
    You would parent them to a null at the center of your comp and rotate the null. Then on the objects you would alt-click on rotation, pick whip to the null and add minus sign to counter the nulls rotation.
    -thisComp.layer(“Null 1”).transform.rotation
    Here’s a sample project if I wasn’t clear: 5612_rotation.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Hope Holmesby
    March 10, 2013 at 1:37 pm
    Dear John,
    Thanks so much. Will give it a try…Unfortunately am running AE 10, so cant open the AE 11 file. But will see if I can do it.
    So, so sweet of you.
    Appreciate.
  • Hope Holmesby
    March 10, 2013 at 1:49 pm
    Hi again…just realized after trying this brilliant suggestion, that want we want, it is to actually rotate them not in an exact circle, but in an elliptical shape.
    What do you think?
    Warmly,
    Hope
  • Hope Holmesby
    March 10, 2013 at 3:43 pm
    Hi John…
    Ok, got the AE 10 project…and got mine to work, based on it…thank you so much.
    I guess if one wants to do something like this in an elliptical path, then either one has to make the circle version first, then pre-comp it, and scale it to an elliptical in the new comp.
    To anyone else trying this….seems one has to have the CTI on the first rotation keyframe to get it to work.
    OR
    just have to hand keyframe each item to go in the elliptic?
    Is this right?
    THANK YOU SOOOOOOO MUCH!!!
    Warmly,
    Hope
