Activity Forums Adobe After Effects Expressions Flower Petals – Replication – Control – Help!
  • Flower Petals – Replication – Control – Help!
    Posted by David Chaudoir on October 2, 2007 at 3:33 pm
    I’ve been using After Effects for a few years now but consider myself a dunce at expressions. I’m somewhat baffled by it all – so have completely avoided them ….until now. Anyway I have a project whereby I will have to animate petals on a flower loads of them and sequentially. Now from what I’ve seen this is the kind of thing that expressions does really well. Has anyone done a tutorial on this or is there an expression out there that can help me?
    Thank you… David
    David Chaudoir replied 18 years, 11 months ago 3 Members · 4 Replies
  • Kevin Camp
    October 2, 2007 at 4:24 pm
    you would need to be more specific about how you want things to animate if you wanted help creating an expression or finding a script that would work…
    you might also look at echospace, a plugin that is very good at duplicating layers and fairly easily creating complex arrays of those layers. it might be the easiest way to go.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Dan Ebberts
    October 2, 2007 at 4:26 pm
    I think we’re going to need more info on what you want the flower petals to do.
    Dan
  • David Chaudoir
    October 2, 2007 at 5:41 pm
    The flower is facing the camera – all the petals open up in a mexican wave/ripple around the flower and grow in the same fashion. Does that help?
    David
  • David Chaudoir
    October 2, 2007 at 5:43 pm
    Just had a look at echospce and that looks like it could do the trick. Thanks. David
