Activity Forums Adobe Encore DVD Flowchart. How To Delete?
  • Flowchart. How To Delete?
    Posted by Arve Hansen on October 11, 2006 at 10:09 pm
    In Encore DVD 2.0 i try to use flowchart. Link menu and avi fils together.
    But when you have link wrong menu to another menu? How can you put this back to the buttom of the flowchart so I can start over.
    Joe Bowden replied 19 years, 11 months ago 3 Members · 3 Replies
  • Jeff Bellune
    October 12, 2006 at 12:34 am
    The easiest way is to drag a new link from the correct project element to the proper target. Another way is to make sure the Properties panel is visible at the same time that the Flowchart panel is visible and then select the element or object that is the origin of the incorrect link in the Flowchart panel. Go to the Properties panel and delete the link target in the Link control.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Arve Hansen
    October 12, 2006 at 7:10 am
    Thanks.
    I tried in properties to delete all links, But they are still linked?
    Very strange.
  • Joe Bowden
    October 12, 2006 at 3:10 pm
    Try again.
    If I understand your problem correctly, you need to clear the end action of the first menu. Select this menu, go to the Properties panel, and clear its end action.
    Make sure you read the Help files on how to work with the Flowchart- how to use it should be explained there.
