Activity › Forums › Adobe After Effects › (Flow) Motion Path, object deforms along path?
  • (Flow) Motion Path, object deforms along path?
    Posted by Anders Hattne on April 16, 2008 at 9:01 am
    Hello, hope this query has not come up too many times..
    What I wonder is, if it is possible to use a mask or bitmap, with for instance the shape of an arrow, follow a motion path smoothly so that the body of the arrow bends in the curves?
    I’m not using cs3 where I suppose the puppet tool could help out.. Advice for plug-ins would be welcome too!
    Cheers!
    Anders Hattne replied 18 years, 5 months ago 3 Members · 3 Replies
  • Dino Muhic
    April 16, 2008 at 11:59 am
    I’ve done the same thing a while ago. I used 3D Stroke to make the body of the arrow.
    With 3D Stroke the line (which you can make as thick as you want) bends in the curves of the path. You just have to put the arrow head in front of the body and limit the body length with the Start/End-Parameters in 3D Stroke.
  • Jeff Dobrow
    April 16, 2008 at 2:40 pm
    Particular.
    Custom particle = arrow head.
    Aux_system = emit many particles to serve as the line. (adjust opacity/size maps to taste)
    Use light path to animate head,…..
    best.
  • Anders Hattne
    April 16, 2008 at 3:28 pm
    Wow!! Thanks a lot for quick answers. That seems like quite an inventive solution!! I have to learn to think that way!
