Activity › Forums › Adobe After Effects › Florescent light flicker: Help!
  • Florescent light flicker: Help!
    Posted by Scott Lakey on September 16, 2008 at 6:47 pm
    Help! I have some footage shot with 60i DVCAM in SIngapore and there is a 50hz flicker in the pictures from the florescent tubes in the background. I did not see it when it was shot. What can I do to fix it? Color stablizer possibly or ? Any suggestios for settings? In desperate shape to fix this problem. Scott
    David Bogie replied 18 years ago 3 Members · 2 Replies
  • Chris Wright
    September 16, 2008 at 9:27 pm
    If the flicker is only in the background, then use a mask feather after you have removed flicker.
    deflicker a free excellent flicker remover
    https://compression.ru/video/deflicker/index_en.html
    There’s other ones like donald graft, tinderbox’s flicker remover, google deflicker might find some more.
  • David Bogie
    September 17, 2008 at 7:37 pm
    We see this issue about three times a year. There are many different approaches. Which you use depends on yor need for quality and your expertise in AE. Easier and cheaper to have someone reshoot it, though.
    I use the color Stabilizer filter in AE. I have brought 30fps material into a 90fps comp to make every frame last for three frames. This allows you to do some tweaking to the filter.
    You might then take this rendered output, speed it up 3x, and lay it over your original using any of several blend modes.
    bogiesan
