Activity › Forums › Adobe After Effects › Flop + mask
Flop + mask
Posted by Stig Olsen on October 25, 2013 at 9:27 amHi,
Im having trouble when trying to mask a flopped image. I have also tried to precompose the flopped layer and then apply the mask.
Any solution?
Stig
Darby Edelen replied 12 years, 10 months ago 3 Members · 4 Replies -
Matt Callac
October 25, 2013 at 6:10 pmIf you have already applied the flop, you need to make sure you select “leave all attributes” in the main comp. Now within that pre comp, you should have an unflopped image you can mask.
-mattyc
Stig Olsen
October 25, 2013 at 6:44 pmHi,
My issue is that when Im selecting (masking) a part, it actually selects an another part than Im selecting, when the image is flopped.
I dont know how to explain it better.
Try to flop an image and apply and feather a mask and you will see what I mean.Stig
Matt Callac
October 25, 2013 at 7:37 pmRight that has to do with the after effects order of operations, which you can’t change. But if your mask is in the precomp and your flop effect is in the main comp you should be good. When you need to modifiy your mask, you need to go into the precomp.
-mattyc
Darby Edelen
October 25, 2013 at 9:24 pm[stig olsen] “My issue is that when Im selecting (masking) a part, it actually selects an another part than Im selecting, when the image is flopped.”
I can’t recreate this issue. Can you provide a sample project file?
Darby Edelen
