Activity › Forums › Apple Motion › Floor-less Reflection
Posted by Don Smith on December 17, 2013 at 12:20 pmThere is a technique of creating of creating what I call ‘floor-less’ reflection that involved cloning a layer, flipping it and putting a rectangle over the clone and changing its fill to gradient and putting it into an image mask applied to the clone. Yada yada yada.
It seems that somewhere I heard that its much simpler to get a reflection without putting in a reflective floor using Motion 5.
Is that true or is it wishful thinking?
Stephen Smith replied 12 years, 8 months ago 6 Members · 8 Replies -
David Eaks
December 17, 2013 at 12:49 pmI think I remember seeing something about that too, maybe Macbreak Studio? I’ll try to remember…
David Eaks
December 17, 2013 at 1:18 pmDuplicate the image, flip it upside down, move it to the bottom of the original and blend with a feathered mask and opacity?
Robin S. kurz
December 17, 2013 at 1:34 pm[Don Smith] “There is a technique of creating of creating what I call ‘floor-less’ reflection that involved cloning a layer, flipping it and putting a rectangle over the clone and changing its fill to gradient and putting it into an image mask applied to the clone. Yada yada yada.”
That’s the only way that I would know of without the use of an actual reflective object. Otherwise you could try using a white “floor” for the reflection and then applying it with a composite mode such as Overlay over your backplate, if that’s what it is you’re looking to do.
– RK
Andy Neil
December 18, 2013 at 3:32 amSo, you’re looking for a way to create a reflection that doesn’t use either of those techniques?
Andy
https://www.timesavertutorials.com
Don Smith
December 18, 2013 at 10:27 amAndy… Yes. I sometimes need the reflection as if a floor is there but without a floor object to block the background. There’s the old technique as I describe in my OP but I thought I had heard somewhere along the way that you could achieve that reflection in the newest Motion without using a floor object and without the complexity hoops of the original technique.
It must have been a hallucination! 🙂
NewsVideo.com
Mark Suszko
January 14, 2014 at 5:38 pmI’m still stuck in Motion 4 but seem to remember it has a “reflection” filter somewhere, might be M5 does too. I’ve manually made reflectives like this, in the way you’ve described, but the free plug-in from Noise Industries, called cover flow or cover flux, seems like an easy to customize starting point. Maybe you can modify that into a template that is re-useable for you?
Stephen Smith
January 14, 2014 at 5:41 pmReflections are easy to do in Motion 4 with its built in reflection feature. Take a look at this tutorial: https://library.creativecow.net/articles/smith_stephen/reflection_4.php
Stephen Smith
Check out my Vimeo page
