Activity Forums Maxon Cinema 4D Floor is Darker than Background?
  • Floor is Darker than Background?
    Posted by Ethan Wright on June 21, 2012 at 4:29 pm
    I haven’t seen any problems with this anywhere else so I don’t know what’s up.
    Basically, I have added a PNG sequence and animated it onto both the Background Layer and the Floor. The background is as it should be, however the floor is darker when I render it out. I don’t think it’s a matter of lighting since I’ve done this sort of thing many times without lighting and it’s worked just fine.
    Also, when my friend creates the same thing with a floor and a background and I load it on my computer it works just fine, making me think it’s not something wrong with the installation and whatnot.
    Here’s an image to show you what I mean:
    https://gyazo.com/dc0846ac637b731ac840013a7cca28e3
    The darker part of this render is the floor.
    Thanks.
    Ruud Van gerven replied 14 years ago 3 Members · 2 Replies
  • Brian Jones
    June 21, 2012 at 6:12 pm
    can’t tell without the scene (and at least enough images for one frame)
  • Ruud Van gerven
    August 19, 2012 at 9:13 am
    Add a compositing tag to your floor by right clicking your floor layer > cinema 4d tags > compositing and enable “compositing background”. U have to render to see the effect.
    Grtz Ruud
