Activity Forums Media 100 Floh – Can you confirm?
  • Floh – Can you confirm?
    Posted by Christopher Kinsman on January 8, 2007 at 5:24 am
    I’d like to install the new M100 codecs described in the Aug 13 post from AJ Metz. I understand this will speed up some rendering as well as allow Compressor to read M100 reference/selfcontained files. (It’s been crashing “Codec Not Installed”.) There are three codecs listed in my Library
    Floh Peters replied 19 years, 8 months ago 3 Members · 3 Replies
  • Floh Peters
    January 8, 2007 at 7:35 am
    You can find the Codecs here, along with an instruction how to install tham. This should speed up your AE rendering dramatically.
    Re the softening, try a short render in AE without moving your source layer down 1 pixel. Maybe this will be sharper…
    Floh
  • Elliott Dunwody
    January 9, 2007 at 3:52 am
    Will this have any speed change for RED?
    Elliott
    Bright Blue Sky Productions
    4811 Rivoli Dr
    Macon, GA 31210
    http://www.brightbluesky.com
  • Floh Peters
    January 9, 2007 at 8:16 am
    [edunwody] “Will this have any speed change for RED?”
    If you are referring to Red as a standalone Render Engine on a Media 100 i system, yes. Red uses either the Hardware Codec or the software codecs if you do not launch it from within Media 100. The software codecs are considerably faster, so all File In/File Out will be much faster. The actual rendering will stay the same, though; so if you have very complex effects the read/write will not have a big share of the rendering time and therefore not affect the overall rendering time that much. But for “easy” effects this will be much faster.
    If you open Red from inside Media 100 i, the movie clips will be handed over from Media 100; inside the Media 100 i application (and for exchange with PlugIns) the hardware codec is used always, so you won
