Activity Forums Adobe After Effects Expressions Floating point trouble
  • Floating point trouble
    Posted by Terje Lundgren on October 9, 2017 at 9:53 am
    I have a variable called “workDur”, which is assigned the result of calculating floating point values (from different layer.inPoints/outPoints & prop.keyTime().
    The workDur value is then assign to activeComp.workAreaDuration. But it ends up being a slightly higher number.
    Any thoughts on why and how to solve?
    alert(workDur); // Result: 1.2
    activeComp.workAreaDuration = workDur;
    alert(activeComp.workAreaDuration); // Result: 1.20000004768372
    /Terje
    Terje Lundgren replied 8 years, 11 months ago 2 Members · 4 Replies
  • Andrei Popa
    October 9, 2017 at 11:04 am
    I’m not sure why the comp has this slightly longer duration. Maybe due to framerate or something, they can not exactly divide it. But i don’t know why this 40 nanoseconds trouble you 😀
    Andrei
  • Terje Lundgren
    October 9, 2017 at 11:41 am
    It renders an extra frame. Quite annoying when the purpose is to create seamless loops.
    /Terje
  • Andrei Popa
    October 9, 2017 at 2:52 pm
    Maybe you should differently declare the workDur. figure out the number of frames you wish to have(i named it framesNumber) and try something like
    workDur = framesNumber*app.project.activeItem.frameDuration
    Andrei
  • Terje Lundgren
    October 10, 2017 at 12:08 pm
    Assuming a 25 fps comp (CC2014), even hard-coding 122 frames (122*myComp.frameDuration = 4.88 seconds) gives an unexpected result:
    app.project.item(1).workAreaStart = 4.88;
    alert(app.project.item(1).workAreaStart);
    // Result: 4.88000011444092
    Manually typing “B” to set the workArea start in AE, brings it back to 4.88 seconds (when checking app.project.item(1).time).
