Activity Forums Maxon Cinema 4D Floating Noise Texture on Cinema 4d Hair
  • Floating Noise Texture on Cinema 4d Hair
    Posted by Ryan Ainge on July 31, 2015 at 4:43 pm
    I’ve created a carpet in cinema 4D and have the desired look. I’ve used noise to vary the look of the hairs, but when I animate the floor that the hairs are attached to, the noise seems to float over the hairs in the render. When I keep the solid that the hairs are attached to static, it works fine, but I need to give the impression the floor is moving underneath the vaccum. I’ve attached a video and project file. In the past, if this was happening on a regular model, I’d change the texture to UVW, but I’m unfamiliar with how the hair tag UVW coords work.
    Video:
    9102_carpetmove.mov.zip
    File:
    9103_carpetmove.c4d.zip
    Ryan Ainge replied 11 years, 1 month ago 2 Members · 2 Replies
  • Adam Trachtenberg
    July 31, 2015 at 8:31 pm
    Do you have the noise set to use Texture space?
  • Ryan Ainge
    August 3, 2015 at 8:47 am
    Changed it to 2D UV space and that seemed to do the trick. Had to tweak the noise a bit to get it to look more like Texture space, but think that’s the solution.
