Activity › Forums › Apple Final Cut Pro Legacy › Float HD Template – can I change it?
Posted by Helena Kristen guenzel on June 18, 2009 at 9:29 pmUsing the Float HD Template (from Master Templates -> 3D Text projects) for a project and need to change the all capital letters to lower case. Is that possible? If so, how can I change that?
Helena
Aditya Vishwanath replied 16 years, 3 months ago 5 Members · 4 Replies -
Shane Ross
June 18, 2009 at 11:49 pmI don’t see anywhere to do that, so I’d say no way to change that.
Hmnmm…
These are Motion templates, so if we can just FIND them we can try to change that possibly…
Shane
Read my blog, Little Frog in High Def -
John Pale
June 19, 2009 at 3:58 amYou sure can change it. Its a regular Motion project located in Templates/3D Text Projects, wherever you installed your Motion content.
I have all my FCS content installed on a separate volume, so its probably in a different place than yours, but you should be able to find it using Spotlight.
If you cant find it, let me know and I can e-mail it. Its only a 600kb Motion project.
Steve Eisen
June 19, 2009 at 5:17 amSelect the text and make sure the all caps is unchecked in the text inspector.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Aditya Vishwanath
June 16, 2010 at 12:40 pmI want to increase the drop zones …. I need to showcase 7 videos.
Can someone please tell me how to create this template from scratch so that I can have it with 7 videosthanks
