Activity › Forums › Apple Final Cut Pro Legacy › Flix Pro Video Dimension Problem
  • Flix Pro Video Dimension Problem
    Posted by Grant Peacock on October 23, 2011 at 1:10 pm
    I have a PAL 16:9 clip exported out of Final Cut Pro. It needs to be converted to .flv format.
    No matter what settings I used in Flix Pro’s video window for ‘Output video dimensions’ the output is always squeezed back into an approximate 4:3 aspect. (Available Flix Pro adjustments are : Use Source Dimensions on/off, No constraints on/off, Maintain source aspect ratios on/off)
    What am I missing? I can’t find any other settings to adjust.
    Rafael Amador replied 14 years, 11 months ago 2 Members · 1 Reply
  • Rafael Amador
    October 23, 2011 at 3:23 pm
    [Grant Peacock] “What am I missing? I can’t find any other settings to adjust.”
    That your 720×576 pixels are PAL Anamorphic, and what you need to display that properly in a web are Square pixels.
    Rescale that to 1024×576. Deinterlace before.
    rafel
    http://www.nagavideo.com
