Activity Forums Adobe After Effects Flipping Multiple Cards in One Composition
  • Flipping Multiple Cards in One Composition
    Posted by Eric Ott on August 16, 2019 at 3:19 pm
    Hello;
    I am flipping 6 cards (two rows of 3) in one composition, the two cards in the center of the composition flip perfectly, but the other cards want to flip to the opposite side of where they are. If I add a keyframe to the position, it kind of works but still a not as smoothly as the two in the center.
    I am assuming that the Y 180 degrees is looking at the composition space and that is my issue. How can I fix this?
    Eric Ott replied 7 years ago 2 Members · 2 Replies
  • Richard Garabedain
    August 16, 2019 at 3:22 pm
    i think it always goes the shortest distance…so if you start your card ad .01 Degrees rather than zero…i think that will solve your problem
  • Eric Ott
    August 16, 2019 at 4:12 pm
    Hi, thanks for answering, can you clarify where to add .01 degrees?
    and I am assuming this is the 2nd half of the flip.
