Activity › Forums › Adobe After Effects › Flipping an object horizontally within a comp
  • Flipping an object horizontally within a comp
    Posted by Stewart Goldstein on August 25, 2005 at 11:33 pm
    Is there an easy way to flip an object horizontally within a comp?
    In this case, there are cartoon characters that are facing one way (say, to the right); I’d like an easy way to flip the characters so they are facing the other way (say, to the left).
    Is there an easy way to do this without having to turn on 3D Layers? Also, I have 5.5.
    Mike
    Steve Roberts replied 21 years ago 3 Members · 2 Replies
  • Michael Duff
    August 25, 2005 at 11:35 pm
    set the x-scale to a negative value ie (-100,100)
  • Steve Roberts
    August 26, 2005 at 12:11 am
    If you also need to scale the thing up or down as well, try doing the flop using effect>distort>transform, making the horizontal scale negative 100 there.
    Steve
