Activity Forums Adobe Premiere Pro Flipping an image in the bin CC
  • Flipping an image in the bin CC
    Posted by Kamau Bilal on August 29, 2013 at 4:13 pm
    Is there a way to flip a clip in the bin? So that when I load it in the source monitor it is already flipped? Currently I have to bring the clip into the timeline and flip it in order to view it properly.
    Corey Wipper replied 9 years, 1 month ago 5 Members · 5 Replies
  • Chris Borjis
    August 29, 2013 at 4:14 pm
    That sounds normal for any editing app.
  • Kamau Bilal
    August 29, 2013 at 4:16 pm
    In FCP 7 I could flip in the bin.
  • Kevin Monahan
    August 29, 2013 at 10:40 pm
    [Kamau Bilal] “Is there a way to flip a clip in the bin? So that when I load it in the source monitor it is already flipped?”
    Hi Kamau,
    I don’t know of a way to do that, sorry. Clips must be in the Timeline before you can add effects to them. You can create a feature request, though: https://www.adobe.com/go/wish
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Kevin Ferguson
    March 13, 2017 at 8:24 pm
    I realize I’m responding to a feature request from 4 years ago: Is there still no way to flip a video clip in the source monitor, instead up needing to do it in the timeline?
    Kevin
  • Corey Wipper
    August 16, 2017 at 7:35 pm
    I often do this for upside-down Ronin shots
    Here’s my work around:
    -Bring the clip into the timeline
    -Go to effects: “transform”, and apply that effect to the clip
    -In the transform effect setting, change the rotation to 180 degrees.
    -Copy the effect, then delete it
    -Go to the “master” tab on the upper left of the effects controls
    -Paste the Transform effect into there.
    Now the whole clip will have this effect burnt into it, even if pulled from project bin again. It will also pull up in the source monitor with the image flipped. To get the effect applied on all the clips, they will need to be pulled into the timeline and have the transform effect pasted into the Master tab of each clip individually. I don’t know of a faster way to apply it to a batch of them at once – because unless you specifically click on the master tab and paste, then it will only paste in the regular effects tab.
    Hope this helps
