Activity › Forums › Compression Techniques › Flipping 35mm footage using compressor
  • Flipping 35mm footage using compressor
    Posted by Kevin Ellison on April 22, 2010 at 2:36 am
    Hi. I have a lot of footage that was shot on a 35mm adaptor, so the videos are flipped and reversed. I know that you can fix this by adding the flop filter in Final Cut Pro and selecting “both”, but really want to avoid doing this for two reasons:
    1. To avoid the render time
    2. To avoid the exporting of these individual clips
    I am presenting these clips to clients to review and annotate through Final Cut Server so I need each clip to be individually flipped and compressed to pro res 422 proxy.
    Can compressor handle this, or am I stuck using Final Cut Pro?
    Thanks.
    Daniel Low replied 16 years, 5 months ago 2 Members · 1 Reply
  • Daniel Low
    April 22, 2010 at 8:55 am
    Compressor doesn’t do DVEs
    Sent from my iPad Nano.
