Activity Forums Apple Final Cut Pro Legacy flip4mac can’t do dissolves!
  • flip4mac can’t do dissolves!
    Posted by Dale Larsen on August 15, 2008 at 10:09 pm
    I have Flip4mac HD version.
    but it will not create a WMV from a multi layered timeline. won’t even do a dissolve.
    It seems you have to generate a composite clip first and then import it back and into FCP and out as WMV.
    same with titles etc.
    I called flip 4 and said sure it does! but I have my doubts.
    I am fully up to date etc. full license
    Any thoughts?
    Dale
    Andy Mees replied 18 years, 1 month ago 6 Members · 8 Replies
  • 8 Replies
  • Chris Borjis
    August 15, 2008 at 10:55 pm
    flip4mac has a number of issues.
    I don’t have any trouble with multi layered timelines though.
    everything is cool except 2-pass vbr.
    what version of final cut pro and flip4mac are you on?
  • Dale Larsen
    August 15, 2008 at 11:07 pm
    i just checked for updates on everything including flip4.
    I am up to date.
    I am using single cbr, simple DV timlines.
    You can do layers? & titles?
    Maybe I need to reinstall. I had a friend on a mac with FCP try it and he can’t do layers either
    Dale
  • Morten
    August 16, 2008 at 7:43 am
    just got to force render everything before exporting from FCP
    – No Parking Production –
    Finalcut Studio2, Dual G5, Kona 2, ioHD, X-Raid
  • Ron Craig
    August 16, 2008 at 4:46 pm
    I posted this issue earlier in the week, reporting the same problem with dissolve failures using Flip4 Mac…even after I rendered the timeline. The only way I could get the dissolves into the .wmv file was to export the piece as a self-contained QT first and then re-import to FCP before exporting again with Flip4Mac. It did not have a problem with titles; they came out fine.
    Chris mentioned above that two-pass VBR encoding is a problem with Flip4Mac and that’s what I was using. Is anyone here getting accurate .wmv exports — including dissolves — using a choice other than 2-pass VBR? Anyone have any more information about that apparent bug? Anyone know if it’s being worked on?
    Ron
  • Dale Larsen
    August 16, 2008 at 7:40 pm
    By force render, you mean going and checking every “render item” available in settings?
    or are there specific ones to check?
    For example, I have a seven minute sequence in DVCPRO HD. (no render need for playback, just simple title over one video layer) this is a watermark not a title from Live type or FCP.
    I checked all the render boxes and the machine wanted an hour to render.
    the same timeline exported as a QT file takes 15 min.
    I just need a WMV final product in the simplest/quickest workflow.
    Ron Craig mentioned he can do titles. please tell me the circumstances.
    HD, SD, where the titles come from?
    any thoughts?
  • Gary Adcock
    August 16, 2008 at 7:53 pm
    [Dale Larsen] “any thoughts? “
    Yeah
    why is no one trying to modify the compressions settings?
    The ONLY one button solution is the OFF button.
    F4M cannot render a dissolve because the default keyframes are too far apart to understand there is supposed to be one in that location and obviously there is not a lot enough of a difference in the footage from one side of the dissolve to the other for it to force a keyframe there.
    reset keyframes in the export to be 15 frames or less the dissolves will render, oh and your compression should look better too.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Ron Craig
    August 17, 2008 at 1:20 am
    They were very simple titles done inside FCP. SD material. Nothing fancy.
  • Andy Mees
    August 17, 2008 at 3:20 pm
    I notice that the latest beta version notes among other bugfixes
    Exporter: Fixed transition rendering issue when using Flip4Mac 2.2 with Final Cut Express
    maybe what you are seeing is a related issue?
