Activity Forums Apple Final Cut Pro Legacy Flip4Mac and Gamma
  • Flip4Mac and Gamma
    Posted by Rafael Amador on June 4, 2007 at 12:26 pm
    I will need to purchase Flip4mac to make .wmv to be watched in some of my clients PCs. My question is, Do F4M compensate for the different gamma Mac/PC so the clips won’t look to dark? It gots any filter or will be necesary a QT movie with the gamma already chaged?
    Thanks in advance.
    rafael
    Rafael Amador replied 19 years, 3 months ago 5 Members · 5 Replies
  • Jerry Hofmann
    June 4, 2007 at 1:37 pm
    WMF’s won’t automatically change the gamma levels for PC playback don’t think, so you’d need to do that manually with FCP or I think there may be a way to do it with flip4mac… not sure… I am sure though that Episode Pro has filters for the job.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Keith Koby
    June 4, 2007 at 2:39 pm
    Do you need to boost or reduce gamma when exporting for a PC in WMV (through episode)?
  • David Bogie
    June 4, 2007 at 2:40 pm
    The gamma is there but it’s not a universal setting. You can get a good target but most monitors, especially projectors and laptops, are all different. We add a bit of brightness, too.
    We created a 1 minute clip that had a wide range of chroma and scene values. We then ran it trough Flip using different settings. This is important: You’ve got to figure out a way to tell the files apart!
    Use a file name or do what we did: super the brightness/gamma settings over the clip.
    bogiesan
  • Tom Brooks
    June 4, 2007 at 3:05 pm
    Compressor has the controls you’ll need for gamma, brightness and contrast. The Flip4Mac encoder works within Compressor. We turn gamma down and contrast up.
  • Rafael Amador
    June 4, 2007 at 3:43 pm
    Thanks everybody. The solution that Tom points, through Compressor can be the way. Although I’ll have a “google’ to Episode.
    Cheers,
    rafael
