Activity Forums Blackmagic Design Flip image on import – a question for BMD
  • Flip image on import – a question for BMD
    Posted by Fredriksdv on November 20, 2006 at 3:56 pm
    Would it be hard for you to make a “switch” in the capture window of APP to flip/rotate the image on capture? I’m currently using your product with a Canon XLH1 in an SDI uncompressed workflow, which by the way is flawless and impressive and miles beyond HDV/DV. I’m in the process of buying a Redrock M2 35mm lens adapter. Due to technical issues, the M2 flips the image (or rotates 180 degrees i guess) on output. I know its not a big deal to rotate it in the timeline, but it would be so much nicer to have original clips that are properly rotated…
    I guess what I’m asking is: Will there be a way to simple DVE stuff to the signal before it becomes a data file?
    Fredrik Harreschou
    FredriksDigitaleVerden
    Fredriksdv replied 19 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
