Activity Forums Adobe After Effects flikckering text.
  • flikckering text.
    Posted by Riccardo Zito on August 19, 2005 at 6:11 pm
    Hello people,
    do I have to antialiase text in after effects or is it already antialiased..
    I am playing stuff out and it flikers..
    r.
    hotmale
    Filip Vandueren replied 21 years ago 4 Members · 4 Replies
  • Filip Vandueren
    August 19, 2005 at 7:21 pm
    If the quality is set to high, it is anti-aliased.
    But I always add a Gaussian Blur of 0.25 – 0.75 px. to every text-layer
    This gets rid of the movement-flicker.
    And also an adjustment-layer on top of the comp with a vertical blur to kill detail-flickering.
    Of course don’t use a font with too much detail like fine serifs or scripts.
  • Roland R. kahlenberg
    August 20, 2005 at 10:40 am
    A transparency setting of approx 90% helps. Lowering the Saturation setting to between 16-235 prevents chroma crawl (which may look a lot like interlace flicker) and is a good thing.
    HTH
    Roland Kahlenberg
  • Karpeev
    August 20, 2005 at 1:17 pm
    The real solution is to put on a field option when rendering. Normally there is “no field”. But try to choose “Low field first” and then render with it. Let me know the result.
    Mike
  • Filip Vandueren
    August 21, 2005 at 10:23 am
    I guess it’s how we interpret flickering.
    Even with Field rendering, you can still get that slight creeping anti-aliasing error if you don’t blur slightly. Especially when you’re moving text vertically.
    You do get rid of jittery or blocky horizontal motion with field-rendering though.
    Having Motion-Blur on helps too.
