Activity Forums Adobe After Effects flight through clouds over a map just like a flight with a aeroplane
  • flight through clouds over a map just like a flight with a aeroplane
    Posted by Thea Birgit on February 8, 2006 at 2:23 pm
    Hi together
    my question:
    I want to fligh over a map for axample germany (psd file) – with the camera. One should have the impression, that there is a aeroplane witch is just comming down. My problem
    1. when the camera comes down the map will be not sharp but pixelated
    How can I avoid or minimize this problem ?
    2. How could I manage it to fly through some clouds ?
    Thanks for answering
    greetings from munich
    Thea Birgit replied 20 years, 6 months ago 4 Members · 4 Replies
  • Erik Lindahl
    February 8, 2006 at 3:21 pm
    There are two options here I’d say.
    1. Make a HUGE pixelbased map in Photoshop.
    2. Make the map vectorbased in Illustrator
    This could be done with the clever partikles I’d say. Use Particular och Particle Illusion for best effect.
  • Barend Onneweer
    February 9, 2006 at 8:51 pm
    Make sure to enable motion blur… when you get closer to the ground, it should help hide some of the resolution problems…
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Michael Szalapski
    February 11, 2006 at 5:07 am
    On the Adobe Studio Exchange there was a comp set up using fractal noise. It looked really good. Takes a long time to render on a slow machine, but looks smashing. It was called night flight.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
  • Thea Birgit
    February 11, 2006 at 10:26 am
