Activity › Forums › Adobe After Effects › flight board look
flight board look
Posted by Dan Roth on March 17, 2009 at 7:25 pmi want to create the effect of the text on a flight deperture display, as seen in the image i uploaded. how can i use ae (or photoshop for that matter) to create that dotted text look?
thanks
danFilip Vandueren replied 17 years, 5 months ago 5 Members · 6 Replies -
Chris Wright
March 17, 2009 at 7:41 pmI’ve used that font before.
https://www.dafont.com/has really nice ones all free. just add a green glow to them and animate scoreboard. It’s actually fun.
Kevin Camp
March 17, 2009 at 7:46 pmgoogle:
free dot font
and you might get luckier….
otherwise you’re looking at a monospace font, the mosaic effect, the grid effect and quite a bit of time tinkering with the settings and it still won’t look as good as some free dot font off the web…
note, if you are using this for commercial purposes (i.e. you are getting paid for this) there may be stipulations on the ‘freeness’ of the font (i.e. you may need to buy it).
just read the fine print to make sure you (and/or your client) are not at risk…
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Dan Roth
March 17, 2009 at 7:51 pmthanks guys.
chris: what did you mean about animating the scoreboard? -
Chris Wright
March 17, 2009 at 7:57 pmSome big ones don’t change instantly. They dim down and up, roll, flip, etc…just to be cool or technology behaviors?, I’m not sure, I just emulate them.
Rob Jackson
March 18, 2009 at 12:00 amThis type of font is commonly called “dot matrix”. I believe there is also one called “Diodos”.
Good luck and post your completed video if you can. I’d like to see how you use it.
Filip Vandueren
March 18, 2009 at 4:22 amTip for nice animtion:
I once used a standard decode effect, but with some posterized gradients tied to a time-displacement, so the decoding happens a few frames later for each horizontal line:
