Activity › Forums › Apple Final Cut Pro Legacy › Flicker/speckles in moving graphic
  • Flicker/speckles in moving graphic
    Posted by Videobiker on August 16, 2005 at 2:35 pm
    I have applied a small scale increase and rotation to a still image. After rendering the image the graphic plays back with what appears to be a flicker/speckles all over the place. What’s the deal? Does this a;ways happen?
    Images are B&W and sepia.
    Biker
    Videobiker replied 21 years, 1 month ago 3 Members · 3 Replies
  • David Bogie
    August 16, 2005 at 2:44 pm
    This is almost always an indication of a bad file. The corruption could be in the original or it might be being introduced anywhere along the rendering path; in the read, the the processing or the write. If the specks are in the exact same place each time you view the effect, it’s happening upstream of the write. If they move, it’s in the read.
    Impossible to diagnose from here, it’s a binary search, though. Try setting your render scratch to a different drive. Try replacing the original file with a fresh copy. Try moving the original file to another drive.
    bogiesan
  • Michael Peele
    August 16, 2005 at 10:05 pm
    Also try doing a small blur (1 or 2 pixels) if these are hi-res images.
    Mike Peele
  • Videobiker
    August 17, 2005 at 12:12 am
    Bogiesan,
    replaced image with new one, re-created move, re-rendered, and it happens again…Always! Now when I apply ONLY scale with no rotation, no speckles!
    Mmmmmmmmm…………………….
    Biker
