Activity › Forums › Adobe After Effects Expressions › Flickering Weld Effect
  • Flickering Weld Effect
    Posted by Ploughman on April 20, 2006 at 7:06 pm
    Im working on a logo that gets cut out by a plasma torch… ive got the emitter from PI and the rusty steel BG in AE7…
    i want to add a lense flare that flickers… I was wondering if there was an expression out there that could help me achieve this effect.
    Harryjf replied 20 years, 5 months ago 3 Members · 2 Replies
  • Tony Kloiber
    April 20, 2006 at 7:35 pm
    Put The lens flare on a black layer animate the flare point then look in the Effect menu>animation presets>behaviors>opacity flash random.
    TonyTony
  • Harryjf
    April 20, 2006 at 7:36 pm
    Maybe add a wiggle expression to the brightness of the lens flare. Something like:
    wiggle(6, 40);
    And I would highly recommend Knoll Light Factory, over the standard AE/Knoll 35MM lens flare. It even has some sort of welder torch preset, I believe.
    http://www.graymachine.com
