Activity Forums Blackmagic Design Flickering Video Problem
  • Flickering Video Problem
    Posted by Kevlareditor on June 28, 2005 at 2:02 pm
    Hi, I’m running Combustion 3.0.4 on a 2g G5 with 4.5 gigs of ram, Huge SCSI Array, Atto controller, and a Decklink Extreme. OS is Tiger with latest updates with Quicktime 7.
    I’m getting a flickering of the video image on both the Combustion display and the video monitor. I also see it if I scrub the clip picons. I had this before I installed the ATTO and Huge, so I’m assuming it’s the Decklink and or it’s drivers. I also have Combustion on my home machine under Tiger and don’t experience these problems.
    The flickering is black, sometimes covering half the frame, sometimes the entire frame. also there are some fine blue dashes on the edge of the black areas.
    UPDATE: It appears to be the Blackmagic codec doing this. But this is the only program that hast this problem.
    Thanks for the help.
    Kevlareditor replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
