Activity Forums Apple Final Cut Pro Legacy Flickering that occurs in cross dissolves after compression in FCP 6
  • Flickering that occurs in cross dissolves after compression in FCP 6
    Posted by Ashley Brook on August 10, 2011 at 3:29 pm
    Help! After I compress a sequence with cross dissolves of images (JPEG) with motion for the web (h.264), there’s a weird flickering effect on the cross dissolves. Never had an issue like this before.
    INFO:
    FCP 6, Sequence is in Apple Pro Res 422, 29.97 FR- Compressing to: h.264, keyframe every 30 frames, restricted to 5000 kbs, de-interlaced.
    Thanks so much.
    Rafael Amador replied 15 years, 1 month ago 2 Members · 3 Replies
  • Rafael Amador
    August 10, 2011 at 4:44 pm
    [Ashley Brook] “keyframe every 30 frames”
    Why do you set that value?
    rafael
    http://www.nagavideo.com
  • Ashley Brook
    August 10, 2011 at 5:56 pm
    I keyframe every 30 frames because the video frame rate is at 29.97 fps.
  • Rafael Amador
    August 11, 2011 at 8:10 am
    [Ashley Brook] “I keyframe every 30 frames because the video frame rate is at 29.97 fps.”
    The time-base has no relation with the number of k-frames you need to set for a good compression.
    Set “Multi-pass” and “Key-frames: AUTO”.
    The “Multi-pass” process will set the key-frames where needed.
    You are restricting already the data-rate; restricting the k-frames won’t help.
    rafael
