Activity › Forums › DVD Authoring › flickering problems
flickering problems
Posted by Chimo on December 5, 2007 at 10:18 amI
Alessio Gemma replied 18 years, 9 months ago 2 Members · 1 Reply -
1 Reply
Alessio Gemma
December 9, 2007 at 8:31 pmHi, I’m sure you see a “strobe” effect, no a “flicker” effect: it’s because you don’t set the field dominance correctly.
In your source material is NTSC, I think you have to select “Bottom field first” or “Lower” for field rendering (I’m in the PAL land, here it’s the opposite: “Top field first” or “Upper”).
If your source is progressive: well, you can encode it as progressive, but your DVD player must be able to read progressive source. Anyway, it’s better to remain in the interlaced world and you have to “interlace” your video.
Regards,
Alessio
