Flickering problem with shape layer
I’m having an issue where this shaper layer is flickering in RAM previews and rendered exports. Its a shape layer with repeater, and opacity changes across the repetitions. Seems to be flickering in the areas with opacity changes.
The problem: https://vimeo.com/202075612/23a0d9742f
I’ve emptied my image and memory cache, tried working in deep color spaces, exporting to various uncompressed media sources. Working in software mode did nothing, nor does exporting with AME vs AE render queue.
I was working in a slightly older 2017 AE version, and just updated to most recent via CC. No difference.
Any ideas? Much appreciated.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
