Activity Forums Adobe After Effects Flickering particle/anomaly ruining composition! Quick solution required!
  • Flickering particle/anomaly ruining composition! Quick solution required!
    Posted by Nick Blake on January 10, 2012 at 11:32 am
    Hi there,
    I have created a title sequence using a series of iris wipe transitions, onto which I have built layers of turbulent displace, blur and colorama to create a burn effect (paper burning from centre outwards). However, there is a strange anomaly that effects (and ruins) the whole animation. A small black particle of turbulence/blur can be seen in the middle-left of screen, even before the transitions begin, which dances around over each of the layers, stopping only after the final wipe.
    I have tried switching off the layers one by one to isolate what is causing this, but can’t seem to find it anywhere…
    Does anyone know what might be causing this? How to fix or a way of hiding it? Need a solution quickly!
    Many thanks
    Nick
    Kevin Camp replied 14 years, 7 months ago 2 Members · 1 Reply
  • Kevin Camp
    January 10, 2012 at 5:08 pm
    without really looking at the comp, or at least a sample image of the issue, it’s really hard to tell, but i it sounds like there is an iris wipe that is not set at zero and is producing the ‘speck’ until it wipes off.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
