Activity › Forums › Apple Final Cut Pro Legacy › Flickering on text out to NTSC
  • Flickering on text out to NTSC
    Posted by Aaron Strader on August 30, 2005 at 2:32 pm
    We’re burning some projects off the timeline to DVD and when we play it back for review, titles made in FCP are flickering on a television.
    Any reason why this is occuring? I’m not too keen on what all FCP is doing to the title, since I personally work more in AE for titles. Any ideas?
    Thaxter Clavemarlton replied 21 years, 1 month ago 2 Members · 1 Reply
  • Thaxter Clavemarlton
    August 30, 2005 at 3:43 pm
    One of the traps in adding text to video is you cannot make QUALITY EVALUATIONS based on the Canvas window on the computer screen.
    If you do, you can end up making the wrong creative/corrective decisions.
    You need to view the FCP output on an external video monitor (NTSC or PAL, depending on where you are) to check motion and/or quality of a FCP image or graphic DURING the edit (this is how FCP is designed).
    The better the quality of the monitor, the better you can judge the levels, color and resolution of the edit… but in a pinch ANY outboard monitor will show you how the actual motion will appear and relative sharpness of the image you’re working with.
    This is a must for making these evaluations on any project that will be output to tape or DVD.
    As to specifics of titles on a DV timeline:
    https://www.creativecow.net/articles/hodgetts_philip/titles/index.html
    https://www.kenstone.net/fcp_homepage/perfect_titles_phil.html
