flickering of a still image sequence
Hi there.
I’m working with hand-drawn animation brought into aftereffects as png image sequences at 12 fps. When I export the movie, the sequence flickers. I tried changing its frame rate to 24 fps, using each image twice, but it looks the same. Is there a filter or anything that could help eliminate the flickering effects? any suggestions?
thanks in advance for your help
