Activity Forums Apple Final Cut Pro Legacy Flickering menu in DVD Studio Pro
  • Flickering menu in DVD Studio Pro
    Posted by Tatyana Mircheva on October 19, 2012 at 3:54 pm
    I really hope someone can help me. I’ve spent hours reading about this issue on the internet and still havent found a solution.
    I created a menu in Photoshop. When I import it in DVDSP on the preview it seems fine. When I burn it to dvd there is a pulsating flickering in certain parts of the photo-around the eyes of the person on the image and some letters. I tried to blur the letters and image, but nothing improved. Watching the dvd on a mac shows the same issues.
    Thanks in advance,
    Tatyana
    Tatyana Mircheva
    Eric Pautsch replied 13 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
  • Gary Milligan
    October 19, 2012 at 4:27 pm
    [Tatyana Mircheva] “I created a menu in Photoshop.”
    Did you create the menu at 720 x 480 – 72 dpi? If not, then DVDSP had to scale it, which it doesn’t do very well.
    HTH
    Gary
  • Tatyana Mircheva
    October 19, 2012 at 4:46 pm
    HI,
    Thanks for replying. I created it with a sizer 720×576 (SD PAL)…
    Tatyana Mircheva
  • Joseph Owens
    October 19, 2012 at 4:48 pm
    DPI is irrelevant.
    The absolute square pixel count is, and 720×480 is correct for 4×3 SD NTSC DVD. Create 853×480 for 16×9.
    PAL is different — 720×576 for 4:3 and 1024×576 for 16:9
    jpO
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Tom Matthies
    October 19, 2012 at 5:06 pm
    Is the menu made from a frame of video you imported into Photoshop? If so, did you deinterlace? You won’t see this while in Photoshop, but it will be noticeable when the graphic is brought into DVDSP.
    E=MC2+/-2db
  • Tatyana Mircheva
    October 19, 2012 at 6:24 pm
    Hi guys,
    the menu was created with a good quality image-not a screen shot.
    Tatyana Mircheva
  • Eric Pautsch
    October 20, 2012 at 2:36 am
    If youre watching it interlaced, then its probably a moire effects from interlacing. Smaller objects and certain patterns will cause this.
    We’d have to see the menu itself
  • Eric Pautsch
