Activity Forums Adobe After Effects Flickering Fonts
  • Flickering Fonts
    Posted by United Fan on November 27, 2007 at 1:55 am
    HI all,
    this is one i’ve not seen. Just got a new MacPro with Leopard and CS3, 10gb RAM.
    I’m moving a font with position keyframes from one side of the screen to the other.
    Yet when it appears and moves, the fonts flickers between the normal font and a default font, as if it’s flickering between arial and garamond.
    i validated the font in Font book and found that it’s doing to other fonts as well…
    any help would be appreciated.
    thanks
    Steve Roberts replied 18 years, 10 months ago 4 Members · 4 Replies
  • Darby Edelen
    November 27, 2007 at 3:34 am
    I haven’t seen this either. Have you tried purging your cache under Edit > Purge?
    Other than that the only thing I can suggest is restarting your computer!
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • United Fan
    November 27, 2007 at 4:32 am
    yea, i tried that….it’s a font that i received from a client. The font is acually named after the client, that type of thing…i’m wondering if it’s a Leopard thing, because it worked on my G5.
    oh well…i just re-created in Illustrator…gotta roll with the punches i guess…
  • Kevin Camp
    November 27, 2007 at 4:34 pm
    very odd…
    if it’s not a problem with leopard and cs3, and you’ve rebooted, the only thing i can think of trying is to place the font in another font directory. osx has 3 font directories:
    1. library/fonts
    2. system/library/fonts
    3. users/username/library/fonts
    i usually install fonts in the library/fonts directory, i leave the system/library/fonts just for system fonts, and i have yet to add fonts to the user-fonts directory, but trying any of them may be worth while…
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Steve Roberts
    November 27, 2007 at 4:44 pm
    Weird.
    If you have time, are you able to contact the font designer, to see if they’ve done anything unusual when creating the font, or when porting it to Mac?
