Activity › Forums › Adobe After Effects › flickering effect
flickering effect
Posted by Ivano Darra on July 5, 2011 at 12:21 pmHello
apologies first of all if this question has been submitted already.. I’d just like to know what effect is used to do the flickering effect found in the end titles of this videos? (it might have been done in FCP though…)
Thanks!https://www.youtube.com/watch?v=tQIUV_cSll0
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Ivano Darra replied 15 years, 2 months ago 4 Members · 4 Replies -
Kevin Camp
July 5, 2011 at 1:05 pmyou can probably create something pretty similar with turbulent displace and posterize time…
add turbulent displace to a text layer, decrease the size and amount (so it doesn’t look like water waves) and animate the evolutions (you’ll want it to be pretty fast).
then add the posteize time effect and set it to 5-10fps (or maybe less).
if you wanted it to repeat the same 5 frames or so over and over, you could use hold keyframes for the evolutions at the rate that you want (you wouldn’t need posterize time), then compy/paste those keys over and over for the duration you need. or you could use just the 5 keys that you need, then add an expression (select property with keys and choose animation>add expression). then type:
loopOut()
and those values will loop for the duration of the layer.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Robert Paynter
July 5, 2011 at 3:06 pmAlso adding a roughen edges might work for you. Then applying the same method of posterizing time or adding some random hold keys on a few different values of the roughen edges evolution then doing a loop expression. This might give you that sketchy look.
Tudor “ted” jelescu
July 5, 2011 at 3:18 pmOr you can do it the old fashioned way- draw/write the plates yourself and then trace on top (different layer or paper depending of the method). The variation of the hand drawn lines will give you a nice organic look. Do that 4-5 times and you should get enough for a loop which you can time remap after if you want the “flicker”/jitter speed to slow down or to be variable.
Tudor “Ted” Jelescu
Senior VFX Artist -
Ivano Darra
July 5, 2011 at 5:40 pmthanks guys, it works! I used them all – turbulent displace, posterize time and roughen edges. As for the last advice I am not really into drawing myself, but maybe one day I’ll give it a go!
