Activity Forums Apple Final Cut Pro Legacy Flickering effect from 3 way Color Corrector
  • Flickering effect from 3 way Color Corrector
    Posted by Gerard Gentil on April 16, 2009 at 2:19 pm
    I used the 3 way color correction for the first time following Richard Harrington’s tutorial and I successfully got the results that I wanted except that I now have a flickering effect in some parts of the image, even after rendering. How can I get rid of that disturbing effect?
    Thanks in advance for your help.
    G.
    Eric Spears replied 13 years, 10 months ago 6 Members · 19 Replies
  • 19 Replies
  • Rafael Amador
    April 16, 2009 at 4:20 pm
    Hi Gerard,
    Had you put too many key-frames or too closed?.
    rafael
    http://www.nagavideo.com
  • David Roth weiss
    April 16, 2009 at 4:25 pm
    It sounds as if your material isn’t full rendered. Go to Sequence>>Render All and make certain to put a check mark by everything in the list just as you see below, especially “Full.” Then perform Render All.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Gerard Gentil
    April 16, 2009 at 8:50 pm
    Hello Rafael,
    Thank you for getting back to me so quickly. I don’t quite understand what you mean by too “closed”. That would be great if you could explain. Obviously the 3way Color Corrector is completely new to me so I also could have had too many Key-frames… I must be missing something.
    Thanks for wanting to help,
    Gerard
  • Gerard Gentil
    Hello David,
    Thank you for your prompt reply. After reading your message I checked the window that you mentioned and in fact the most important part, which you said was “Full”, was not checked. So I will re-render and let you know the result.
    Thanks a lot for you help,
    Gerard
  • David Roth weiss
    April 16, 2009 at 10:30 pm
    [Gerard Gentil] “in fact the most important part, which you said was “Full”, was not checked.”
    Of course, I knew that Gerard. All of us with pictures above are psychic you see. Rafael knows a lot about video, but he is just a calf and has yet to develop horns, so his psychic powers are not yet developed.
    BTW, I also know that when you render your problems will go away… Besides being psychic you see, I can foretell the future as well.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Gerard Gentil
    April 16, 2009 at 10:34 pm
    Humm, very interesting David, since after rendering the problem still exists… Any more thoughts for my future?
  • David Roth weiss
    April 16, 2009 at 11:30 pm
    [Gerard Gentil] “after rendering the problem still exists…”
    Okay Gerard, let’s back up a little, I need some information.
    1) How are you monitoring? On a computer monitor alone?
    2) What type of video material are you working with? i.e. What codec/framerate
    3) What type of hard drive setup do you have as your media drive?
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Michael Gissing
    April 16, 2009 at 11:42 pm
    A lot depends on what you mean by flickering. Is it changes of luma level, chroma level or perhaps that ‘old chestnut’ field order problems.
    Even super psychics like David need a better definition of the symptoms.
    What Rafael was guessing was that you might have set a whole lot of keyframes close together and the flickering is FCP trying to change settings rapidly.
  • Gerard Gentil
    April 17, 2009 at 2:06 am
    Hi Michael,
    Thanks for your input. Even though I don’t quite understand how that works yet, what you say makes sense. However, since I don’t know yet what I am doing I may have to start from scratch and re-do the entire correction by paying attention to the key-frames. In the meantime I will give to David the information that he needs to see if he finds a solution.
    Thanks again…
  • Gerard Gentil
    April 17, 2009 at 2:29 am
    David,
    Here are some answers:
    1) I am using a Mac-Pro Lap-Top only.
    Just so you know I already formatted the clip into a quick time file (thinking the flickering would go away, since FCP does a lot of things automatically on it’s own) and I also burnt a DVD in order to judge the final product.
    2) I shot on Mini-DV Standard Definition at 29.97 FPS
    3) I am using a LACIE 250 GB external Hard Drive
    To explain the “flickering” problem better, it looks like there’s WIND BLOWING through a curtain backlit, from an over-exposed window in the background and in a flower, also backlit and over-exposed, attached to a girl’s hair in the foreground. The background was under-exposed, that is the reason why I use the 3way corrector to balance the exposure with the previous shots.
    I hope this will help.
