Activity › Forums › Apple Final Cut Pro Legacy › flickering dissolve on nested still image sequences…
  • flickering dissolve on nested still image sequences…
    Posted by Tad Newberry on November 4, 2010 at 3:29 pm
    Two questions on this topic:
    1) can i get my canvas to show me video the way it looks on my external monitor? there is flickering dissolve that doesn’t flicker in the canvas, but it does on the monitor;
    2) why do they flicker at all? i have a short nested sequence of 3 stills. small moves on the stills, and they are all set as a traveling alpha matte over a black square so their moves will all be contained within that box in the final FCP sequence. that part works great, but when i add the shadow to the nested sequence in FCP, the dissolve between the stills plays back with a flicker. i dunno why…
    thanks for helping out a bonehead!
    __________________________
    FCS3
    2.66 GHz Quad-Core Mac Pro
    6GB RAM
    NVIDIA GeForce GT 120
    …and a few TeraBytes o’ storage
    (then it’s on to PetaBytes, ExaBytes and MosquitoBytes!)
    Jerry Hofmann replied 15 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    November 5, 2010 at 3:25 pm
    OH, they flicker all the time, but you don’t see it in FCP’s Canvas because you aren’t seeing both fields for each frame unless the canvas is set to be 100% size.
    I think I’d troubleshoot this by trying a progressive sequence setting and not an interlaced one.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
