Activity Forums Adobe After Effects Flickering color in video payback/After Effects 7
  • Flickering color in video payback/After Effects 7
    Posted by John Martinez on February 16, 2007 at 3:38 am
    Recently, I have found that when I import then playback an avi in After Effects the image will alternate between color and black and white.
    If I import something with an alpha channel, the image, when played back, will alternate between a black and white background and a bright yellow background.
    When I have two or more layers on top of each other, I can see all the layers as though each layer’s opacity was set at much less than 100%
    What am I doing wrong?
    Mylenium replied 19 years, 7 months ago 3 Members · 2 Replies
  • Curious Turtle
    February 16, 2007 at 8:32 am
    If this is something that has just happened recently, then has something changed in your system?
    My first guess without other information would be to update/downgrade you graphics card driver. Depending on your card manufacturer, they may have a recommended driver for After Effects – and it’s often not the latest one they’ve qualified.
    HTH
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Mylenium
    February 16, 2007 at 9:01 am
    There surely has something changed on your system. Either it’s a graphics card related problem as Ben suggested or you updated a CoDec or Mediaplayer.
    Mylenium
    [Pour Myl
