Activity › Forums › Adobe After Effects › Flickering color bars in HD render Quicktimes
  • Flickering color bars in HD render Quicktimes
    Posted by Mark Dugas on September 27, 2008 at 5:31 pm
    I am trying to render to DNxHD codec 59.94 1920X1080 quicktimes. These quicktimes are simple Ken Burns moves over a still image. The images are huge, and sometimes I need to scale them up a lot. Some, but not all, of the final renders display flickering color banding across the rendered QT image. Any ideas what is going on? Thanks!
    Mark Dugas replied 17 years, 9 months ago 3 Members · 5 Replies
  • Grant Swanson
    September 28, 2008 at 1:22 am
    Did you apply any sort of color correction in 8 bpc?
    Grant Swanson
    Visual Effects Supervisor
    Video Apex – Minneapolis, MN
    videoapex.blogspot.com
  • Richard Tsai
    December 6, 2008 at 3:38 am
    Hi Mark,
    I am experiencing the same thing. Were you able to find a fix? The horizontal banding happens only during playback or editing on a Mac. On PCs the files generated play smooth and fine. My only solution right now is to use the QT animation codec.
  • Mark Dugas
    December 6, 2008 at 2:07 pm
    Hi Richard,
    I found that the issue has to do with a Mac playing back the Avid HD codec QTs, but importing the QTs into Avid is fine. So even though the quicktime movies continue to have color bands when played in Quicktime on the Mac, they look fine when imported into the Avid using Avid DNxHD 220 codec. I have no idea why this happens but at least the final result in Avid looks ok.
  • Richard Tsai
    December 6, 2008 at 6:21 pm
    Hi Mark
    Thanks for getting back to me. I am using DNxHD 145, 8-bit/59.94i. For me, the problem is present in the QT player but also during playback in Avid. Again, this is on Macs only. I can’t reproduce the problem on PCs and I’ve tested playback on three PCs here. The final delivery will be to a tv station which is pc-based for the online edit but our offline editor is mac-based, and he is experiencing the issue. I am trying to determine whether there is corruption in the movie files themselves or in fact this is purely a codec bug for mac systems. I would appreciate your thoughts. Thanks again.
  • Mark Dugas
    December 6, 2008 at 7:26 pm
    Hi Richard,
    I am guessing that it is a codec bug for Mac systems. I am importing many of these Quicktimes into a PC Avid system and playback is fine for all of them. If I was you I would send the online facility a few Quicktimes that you know have the issue on a Mac, and make sure they import OK onto their PC Avid timeline.
    Mark
