Activity › Forums › Adobe After Effects › flickering bokeh? like sunlight reflecting off on water? how???
Posted by Agne Jurkenaite on June 22, 2017 at 2:31 pmsomething like this? i was wondering how i could achieve it.. if i could do this from scratch/not from an image so its like an overlay file.
Agne Jurkenaite replied 9 years, 3 months ago 3 Members · 3 Replies -
Michael Szalapski
June 22, 2017 at 6:47 pmThis is more like bokeh:
What you’ve got there is more like a flare or a streak.Regardless, there are many ways to do this. You can use Optical Flares or Knoll Light Factory to make lens flares on the hot points of a video (or an animation you create).
Or you can simply use the Lens Blur effect on something. Or you can use a copy of something with the Directional Blur effect on it set to screen. You know what? Here’s an example: 11462_waterbokehasaeversion12.aep.zip
There are other ways.
– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Richard Garabedain
June 22, 2017 at 10:12 pmso what you need is a series of white circles that go in and out of existence plus optical flares using luminance value to create the flares…for the circles i suppose particle world would be the best choice
Agne Jurkenaite
June 22, 2017 at 11:00 pmthank you both! i think i figured how to go about this now.
